I have a 1995 Ford Ranger XL 2wd 4.0 6 cyl with manual 5 spd transmission and the brakes went out on itI replaced both back wheel cylinders, booster assembly, adjusted brakes and bled till i got clear and clean brake fluid.
Brakes still go to floor and pressdown on pedal.
There are no leaks at master cylinder, but leaking underneath clutch master cylinder reservoir at a 90 fitting.
Clutch is dissengaged
Brake fluid is emptying out of master cylinder reservoir but not clutch master cylinder reservoir
I am at a loss
It almost seems like O ring or seal is bad.
I got no leaks inside cab or at master cylinder.
Brake lines are not leaking.
Any ideas ?
Thank you.
Chris
I am at a loss
Any ideas ?
Thank you.
Chris
