Brake help
coolbrze
I've got a 2002 Ranger 4 cylinder 2wd manual (in sig) and the rear brakes are squeaking. I might as well replace the front at the same time right, it's got 60K orig. miles on it? I went to Advance Auto and apparently there are 2 diff. size shoes for the rear, S705 (10x2.5") & S704(9x1.75"). Which do I need? Also, who makes the best pad/shoe, Wearever, Bendex, or Wagner?
Thanks in advance!
I have a 1986 ford ranger truck 2.3L 2wd I purchase wagner disc pad for $49.78 from O Reilly auto parts and don't squeak
Thanks in advance!
you're going to have to take the drum off and measure it with a tape measure
although, if your ranger is a 4cyl 2wd manual, i think it would be safe to assume its the 9 inch drums
