Brake fluid leaking from tranny when I pump the clutch
Yes, that would be correct, as long as you checked that bleeder is closed, and Quick Connect isn't leaking
Thanks for the response! I'm in the process of taking out the transmission but I can't get this 1 final bolt loose on the bell housing. I got the top 2 bolts loose and the bottoms loose I can't get the drivers side middle 1 loose. I can't get my socket on it I lowered the transmission and it's still a no go
