- Aug 25, 2007
- Automatic
I have a 92 Ranger 4x4 Super Cab 4.0 V6. Have a weird problem with the brake pedal. Bleeding it with the engine off on all 4 wheels gives me a rock hard pedal. Start it up and the pedal same as goes to the floor to stop. I replaced the back brake shoes cause some of the hardware was broken when i was troubleshooting this problem. So new brakes on back the pads on front are better than 50%. I get a swoosh sound just when i push the pedal not a continous vacuum sound when i hold the pedal down. I have had boosters go bad before but they usually make a continous vacuum leak as you keep it held down and usually the pedal gets hard to push. It never bleeds down to where i have to pump it once to hold, to make me think its a master cylinder Anyone else run into a similar problem?
