Brackets ps pump, alternater,ac
Jdobbi
I have a 302 im putting in my 90 ranger, any hints on brackets for ps pump, alternater, ac, etc.....I tryn to use all everything back, so any advise will b very helpful.
The shorter the better. 94-95 Mustang 5.0 and the Explorer 5.0 has the shortest factory setups.
Depending on what your engine is you will probably need everything related including the timing cover. The Mustang uses a more generic harmonic balancer that may be the same as what you have but the Explorer uses a specific one.
This takes forever to load here at work, but make sure there isn't an issue with different engine balances (if that applies to your engine)
http://classicbroncos.com/tech/explorer-5-0-serpentine-accessory-drive-belt-conversion
