li7in6
- Jul 21, 2009
- Automatic
More of a curiosity than something I plan on attempting to tackle in the foreseeable future. How do fabricators make fully boxed control arms (not boxing OEM pieces). I understand the concept behind them, but how does one go about welding and joining all the connections inside of a boxed structure you plan on closing without painting yourself into a corner, so to speak. This has farther reaching application than just suspension components, and I realize might be too broad of a question for a simple answer. And is more to do with experience and order of assembly. But I'd like to get a general idea of whats involved and how its planned for.
For instance, internal ribbing/support in a control arm. I can see how to fab the basic structure and internal supports, but how does one close the box and tie the supports into the "cap" peice without magically teleporting your welder through a steel plate.
One of the ways I can see it being done is using smaller plates and welding the outer shell as you go, possibly using a solid base plat for the lower and piecing together the top. Obviously you're plate work will need to be rather intricate (as with the Herbst TT lowers below)
Another way i can think is to have you're top/finishing/whatever plate have reliefs cut so you're internal bracing can come through and allow you to fuse it to the plate from the outside, but it seems like you'd have to be pretty precise with your cuts. though I guess fabbing suspension arms is pretty precise work in the first place.
From looking at the pics I've seen and looking at the weld burns/penetrations, it might be a combination of these and more.
How do they do it with apparently solid top and bottom plates? Are the arms just hollow?
Any help is appreciated.
pictures for 'how dey do dat' reference:
Assorted pics from Terrible Herbst, Mazulla, Atomic, Boneyard, Camburg, etc.
