Box Bronco 44 Disc Brake Conversion??
mhughes165
Solid Axle Swap
alright, so i know im puttin a box bronco rear under the ranger, jsut the matter of finidn a right one, theres a member on here sellin the drum brakes 44, was wonderin can i do the conversion with junkyard parts, or would i actually need to order parts from like jamesduff or earlybronco.....if i have to order from there its just not worth it to me
IF the parts are the same as a full width 44 then i have ho problems with doin the conversion
Grab everything from the knuckle out on any full size 78 or 79 bronco or f 150. Bolts on and you have discs.
75ish-79 will work. You can also use rotors, hubs calipers off of pretty much any 80's bronco or F150
