sngehl01
- Jan 11, 2016
- Automatic
First of all, new to the forum. Hello all!
I'm an OBS full size guy. Picked up a ranger recently. I have owned 3, but this is the first 4x4 one I have bought. It also needs a lot of love...
First of all, 260k miles on the truck. 4.0 motor but runs good. Rear end has issues, dropped down to check it out and half the differential cover bolts are off. I think I'm just gonna head down to the local pick and pull and pick up another rear end. No huge deal.
The bigger issue (other than the awful mildew smell in the cab) is the automatic transmission being so hard to shift. It's very stiff/firm when trying to select a gear. It seems to do OK once in gear (so far). I haven't had a chance to try it at road speeds, only in the parking lot.
I have read a lot about the valve body gasket on these transmissions not being worth a hoot. Has anyone had an issue similar to mine, and if so, were you able to fix it?
Luckily, I only paid $800 for the truck. Extended cab 4x4. Body relatively clean and straight, big dent in driver side of bed. I think I may build a flatbed for it, but that's a project for when I get it running good.
Thanks all!
Thanks all!
