Beef52751
I finally bought a used one!!! i bought it with a belt so install shouold go smoothly. hopefully ill have it on sometime next week
Beef
Beef
Yes the chirping will happen with older belt. If not using a gatorback, it will chirp like mad when using the AC. The gatorback is the only belt that has held up against the chirping for more than 3 months. The other belts were OK to use, its just they have a tendancy to slip around the aluminum pulley. Good to see your mileage increase. Mine increased as well. Considering that, its paid for itself!
Hmm... I'm not using a Gatorback, and I get no chirping with the AC on.Yes the chirping will happen with older belt. If not using a gatorback, it will chirp like mad when using the AC. The gatorback is the only belt that has held up against the chirping for more than 3 months. The other belts were OK to use, its just they have a tendancy to slip around the aluminum pulley. Good to see your mileage increase. Mine increased as well. Considering that, its paid for itself!
