bottom rad. hose
COPPERHEAD85
west tennessee
what is everybody running for the lower rad. hose?just switched to a mustand rad. because i wanted a 2 speed fan and shroud.
this thing went from a weekend toy to hopefully a dd and iam trying to stay away from putting 2 hoses together.
any help with pics would be sweet!
by the way the mustang set up is a B!#(H to fit but i bought it cheap so i went with it.
thanks all
i have a mustang rad in mine and i run a flex hose with the wound cord inside. Mine is a bit too long, but has always worked.
iam running a serp belt set up off the crown vic donar,what are you running?got a part # for the hose?
With the radiator I have (Griffin 27.5 x 15.5 with the outlet rotated 90*) The lower hose is 4 pieces of other applications spliced with exhaust tubing, it runs up and over the frame, down under and back up to the waterpump. Looks like hell, but it's lasted for 7 years now.
I have a griffen rad i think its 19x2something, Im using like a 90 f-150 5.0 f150 hose, that i cut at 2 parts and put it together with a coupler, I can take pics if you would like them?
if you have time post a few...............thanks alot!
