samsonitesamsonite
I have a spare 4 oh that I am tearing down and completely rebuilding. I'm almost to the stage to send the block off to the machine shop, would I notice much of a difference if I say, had it bored .030 over?
As MAKG said - any increase in 'swept' volume will result in an increase in static compression, so calculate away my friends.
No. Changes in stroke change the compression ratio. Changes in bore do not.
Any change in volume changes the displacement. And I'd really suggest that anyone with questions about whether to do that should calculate stock and modified displacement. This will lay your questions to rest.
MAKG - think about what you just said..........................
Larger bore with the same stroke will mean more swept area to be compressed into the same combustion chamber = higher compression. One of the reasons you can put a 350 crankshaft in a 400 block and with the 350 heads and the same style pistons, the compression ratio will jump an additional point- granted, a .030 overbore on a 4.0 won't change it much, but it truly does happen.
Bird
Bird
No, your combustion chamber will also increase in size. 0.030 in in diameter to be exact.
