bolt patteren
Pyro6669er
cedar hill, Texas
will OEM LINCOLN MARK V TURBINE ALUMINUM WHEELs fit a 1989 ford ranger?? I am thinking about getting these wheels but I don't know if they will fit they are 15x6 5x5....
If the hole pattern is 5*5 then no. The ranger you have needs 5*4.5", as measured from the outside of the first hole to the center of the third hole. Or get adaptor plates.
Also keep in mind the size of the center hole.
A good place to cross reference bolt patterns;
NO. I have a '01 Ranger, my dad has a '98 Lincoln continental, and I tried to swap the wheels to no avail. The lincoln is a smaller bolt pattern than the Ranger.
my dads wheels look similar to this
61525
EDIT: I just googled "LINCOLN MARK V TURBINE ALUMINUM WHEEL". Those look different and are much older thatn the ones I was thinking of. My answer may be useless.
98 Continentals were Taurus based, a whole different animal.
