- Nov 27, 2010
 1984
- Automatic
 Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Is there a four wire connector on the alternator or three terminals on the back. It definately sound like it has been hacked together post some pics will help also. It should have a external voltage regulator on the driver side apron?
From the link I posted
If you are getting less than 13.6v from an alternator with engine running(idle) and all lights and heater fan on then 1 or 2 of the fields in the alt may be dead.
An Alt has 3 fields that produce AC power, it is changed to DC by diodes, a field or its diodes can fail, this means the alt can not produce it's full voltage.
