lil_Blue_Ford
Cut & Weld
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- 4”
I'm in the process of finishing up the bodylift on my choptop. I went with a 2" kit from James Duff.
I have the bodylift on with the exception of two that I need to weld a patch on the bracket, and I started looking at how it changed everything else, which resulted in some questions...
The upper radiator hose is wedged tight up against the intake tube, which is torquing on my airbox pretty good. Is this going to be a problem and if it is, how should I resolve it?
It has an FM-146 trans. I did get a shifter extension, but do I really need to use it? The directions say to put it on and that I need to trim some stuff so it will shift right but it seems to go in all gears just fine.
I have a steering extension that came with it. How necessary is it to put this on? To me it looks like it's not really needed, but....
Does it really matter which way the front bolts go (the ones through the core support)? Stock has them going up from the bottom instead of down from the top, but I don't see how it makes a difference?
Any other tips that you want to share before I do the final tightening?
