detty_motorsports
- Sep 21, 2009
- Age
- 39
- chillicothe,ohio
- Automatic
i was wondering how hard it is to install a body lift on a b2?
the cheapest ive found for a 2 inch body lift is from jamesduff.com quality wise i think most companies are the same but im sure others will chime in
what are the difference between the poly and the other?
its ok i dont mind......
when doing the body lift it is the easiest time to change the body mountsPwrranger88, how do you like those poly body mounts? Doing the body lift would be a good time to change these old ones out...I have used poly trans and engine mounts before and the vibration transmitted to the vehicle was pretty noticeable, did you notice much difference when these were installed?
Sorry for the thread hijack! Ron
he was talking about the cab mounts the factory ones are usually dry rotted and when you do your body lift it is a good time to replace them cause you have every thing apart already. the reason i went with poly because they are allot cheaper then any rubber replacement ones i could findwhat are the other??? i dont really know much about body lifts
i thought the lift blocks replaced the mounts.....
