body lift question
s2pidyeah
Ewa Beach
for a 92'regular cab,long bed,.... is it easy to install a body lift?
and where can i get new body mounts bcuz i only ordered just the lift spacers
You'll need a large Torx bit, T45 or T55, a high lift or some type jack, sockets, and an afternoon or weekend depending on your skills and the amount of rust and other issues oou could potentially run into.
all i used was a thumb wrench and a 3/4" socket and 2 jacks and a chain hoist
should i use floor jacks or a lift
Do you really need jacks? I'm guessing that's to take the cab off. How much would you say the cab weighs?
If you have access to a lift, then yeah, I'd use it. Just undo all the bolts at once and lift it up enough to get in there.
I can't imagine you'd be able to lift a corner of the bed, and be able to get under there to but the block in, much less the cab. But maybe if you're Hercules.
