Body lift help
gearjmr
Hoquiam,Wa
So i recently purchased a 3"PA body lift for my 85 b2. i spent a few days sprayin the bolts down with WD40 and spent a few hours bustin loose the nuts.
as i was liftin the driver side i got 2 outta the three blocks on when i noticed that the rear part of the body wasnt lifting. so under further examination i realized that i missed the back two bolts.....well DUH!!:idiot:.
so does anyone know of a way to get these damn things off besides dropping the skid plate and fuel tank?
thanks guys
Sorry I really couldn't tell you but I have the same truck and I would really to see some before and after pics of it. And what size tires will you be running?
you can get the bolts out by pulling the rear carpet out and taking the plates that cover the bolts off I had a friend use a box end he just held it up while I hit it with an impact and he let it wedge against the frame for a hold back.
I unfortunatly had to remove the skid plate and gas tank! Then they would not break loose so out came the air cut off tool.
