Oil pressure is from back pressure.
The oil pump picks up the oil and sends it to the filter, after the filter the oil goes into a main passage, where the oil pressure sender is, and then into smaller passages to the crank/rods and cam/lifters and up to the valve cover via push rods.
The gaps in the bearings only allow a little bit of the oil to pass so back pressure is built up in the main passage, more oil is coming in than can get out, and that is the oil pressure you read.
The bearings let out the same amount of oil all the time, RPM doesn't change that, but RPM does change the amount of oil coming in from the oil pump.
That is why oil pressure goes up as RPMs increase, out flow from the bearings doesn't change but in coming oil flow is more.
A little more oil is pushed up to the valve cover at higher RPM, but not enough more compared to the increase of the oil being pumped by the oil pump.
So for oil pressure to drop as RPMs goes up is a puzzler, but if the oil pressure at idle was 6psi(normal) and the oil pick up was getting clogged up then as RPMs increased the oil flow would remain the same, no increase because of the clogging, and the extra oil going up to the valve cover could be enough to drop pressure below 4psi, which would trigger an Oil Light or cause 0 on a gauge.
If clogging was bad enough then oil pump at higher RPM would actually go to 0 output, basically create a suction at the filter.
And yes....if its that bad up top then bottom end will be the same.
