RangerFabWorks
The O.G blackwidow67
⭐Supporting Member
💻 TRS Socials
- Jan 31, 2009
- Age
- 34
- Lexington
- State - Country
- NC - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- Manual
- Tire Size
- 235/70 275/60
my 2.3 blew on me. it had 78,000 miles. it was original. it puffed a little smoke on a cold start up, used 1 quart every month. but ran like a top. so i just put 200 dollars in tune up crap to the engine, finally got my carb tuned, advanced the timing to spec. drove it in the morning and it felt great. had the windows down, was cranking eric clapton, but on my way to work and i had a typical ny driver behind me. so i wanted to see how see was performing, mind you i didnt beat on it so to speak and ive done this a couple times before. so i normally shift a 3,000 rpm, well with this nice driver, i wanted to dust him a little, so i rev out 1st gear to 4,000, everything is fine, so i get a little more brave with 2nd, rev it out to 5,000 rpm, everything is cool, im as far ahead as you could be with a carbed 2.3 and a 4-speed. i shift to 4th, and i noticed it starts slowing down. now i had the same problem once before, but it was bucking in 4th, so i pulled over and let her cool down and it fixed itself that time, well thsis time, im slowing down a lot, i look in my rear view mirrow to see a big cloud of blue smoke. GREAT, so i take an exit ramp, drive another 3 mile to the nearest gas station, and i notice is only hitting 3 cylinders. so im thinking i bent a valve. im 10 miles from home, i cant get it towed. so with 3 cylinders and the balls of a horse, i drove it home. so i start it up the next day to move it to tear the head apart. now its got no oil pressure and it stalled and blew the oil dipstick out and a puff of blue smoke filled the engine compartment. so i start it up and move, go to tear the head apart. and no bent valves, WTH? so i pull the head off, blew the number 2 piston to pieces and the pieces went to the oil pump and locked the pump up. how does this happen? i thought you could rev these engines to 6200 rpm? the only thing i did different, was i have 20-50 oil and i put that lucas crap in with it. i dont think the lucas did that? does anyone have a clue as to why this happened? the engine was not a shot, knocking old motor, it still had life in it.
