sholzy
I have a 93 4.0 190K miles. I was driving around in stop and go traffic the
other day in this Texas heat w/AC on and my temp gage was reading much hotter
than normal. ( C_______^__H). Upon accelerating from a stop a little harder than
normal I notice a cloud of smoke I left behind. This is the first this truck
smoked so it was a bit horrifying to see that much smoke
. Letting off
the gas the smoke eased up also. I pulled into a gas station to check the damage
and found oil dripping from the rear of the engine. My first though was rear
main seal.
After getting the truck home and not wanting to drop the tranny, I was reading
on this forum about a bad pcv valve causing excessive blowby and checking by
removing the oil filler cap and checking for smoke while the engine is running.
I checked that but no smoke and changed the 2 yr old valve anyway. I then
decided to warm the engine to its normal running temp (C__^_______H) and go for
a road test. I accelerated hard to 70. No smoke. Pulled over to look for
dripping oil like I saw before. None. Turned around and did the same thing. Same
results. I wasn't convinced I needed to pull the tranny and replace the seal.
Trailering the truck home I was thinking about a few things. I assume blowby is
greater at hard acceleration and highway speeds (say 60+) than at lower speeds
(say 30)? If my engine was running much hotter than normal the oil will be a
little ( or much?) thinner, and with the hard acceleration, would it be more
likely to push oil out the rear main seal compared to oil that was much cooler
and the same hard acceleration?
I don't want to yank the tranny so I'm hoping my thinking is on track and
I'll get reinforcement of that thought from you guys. Sorry for the long post
but I tried to give as much info as I could.
main seal.
