Tractor Dan
Ok. I had recently swapped in an 8.8 with 10 inch drums. We patched the axle line and the supply brake line together with a barb fitting and hose clamps. Well that failed and we tryed fixing it by sliding a piece of tubing over the spot to act as a compression sleeve. Well it seemed to work but now we aren't getting any fluid past the block that the two steel lines come off. Only thing i can think is that block is clogged. Am i heading in the right direction or not? I would think i am since we are pumping fluid to the block but it's just not distributing out to each wheel through the steel lines. So any ideas???
Dan
Dan
