dernst
- Aug 24, 2008
- Automatic
I’m having trouble understanding a concept behind bleeding brakes. I know how to bleed brakes both manually and with a vacuum bleeder. I don’t see how a bubble in the middle of a brake line can be removed unless there is a large flow of fluid thru the whole brake line. I can see where a bubble will travel to the highest point, but it seems to me that it would take a lot of flow to move it to the lowest point or past a level section.
Is the whole system sloped to only have possible air bubbles at the master cylinder or at a wheel cylinder or caliper? To me, it looks like there are some level sections in the middle.
Any thoughts?
Any thoughts?
