trademarked67
- Mar 16, 2008
2x4 94 ranger 2.3L w/manual transmission, front disc brakes & rear drum
About 2 weeks ago the brake peddle became soft, going to the floor when stopped. I knew the pads and rotors needed to be replaced on the front, so I replaced them along with the calipers. I went to bleed the brakes starting with the right rear. Connected a hose, etc opened the bleeder screw and got nothing. Closed the screw, removed the hose and tried to clean the screw thinking dirt was trapped inside. Reconnected the hose and opened the screw and still got nothing. Decided to try the left rear and could not bleed any fluid from that wheel either. Fluid flows from the front freely when opened.
I can't find any evidence that the lines have a kink or have been crushed. Any ideas what is not allowing fluid to flow?
Thanks
Thanks
