Black rockers or not?
TorontoEdge
I've been toying with the idea for a bit. Black line just at the rocker level (below door seem) with a blue accent line above it.
Not the traditional 2-tone by any means but, it will give the truck a "taller" look and I have some touch-ups to perform anyway so it will be painted red or black.
Here's a quick PSD:
I have no clue... Maybe I'll fix it red and try out the idea with the rubber paint stuff (never can recall the name).
:popcorn::icon_confused:
I like the black. It makes it yours.
I'd wanna check it out in a different light or from another angle or something... 'Cause like that it just looks like everything below the door seam is gone.
If you can't decide, maybe look into plasti-dip. That can be sprayed on to give you some idea of what it'll look like and is supposed to be easily removed later...
I like the look of the black on the rockers. I think I would use a silver, orange or yellow pinstripe instead of the blue.
Use plastidip. It's a temporary solution but you can go back to original look easily.
