Bittersweet Day
spring under will ride better
what are you trying to fit?
If you go SOA you gotta change the pinon angles anyway, and it's easy to do when you weld the spring perches on.
Anyway, here's a shot of his YJ, he's runnin 34" LTBs and this is after the new springs.
i said nothing about SOA neither did samsonite.nor is he talking about add a leafs.there are lots of ways to lift a yj i was showing the best cheap way to get 2"s.if you look at that pic those rediculous shackles drag over everything.
You should see him wheel it.
it seems that shackles would work with something like this tell me what you guys think, I know I would have to figure out what shim I would need, but its a thought.
i'd do a mild lift for the 31s and then go spring over for the 33s
