KurtC
I bought my 90BII back in 04 and the ac system didn't work, so I bought some ester oil, o-rings, fancy variable orifice valve, and R134 and did the retrofit. It's been working fairly well, but I think it could do better, so I'm about to pull it all apart again, replace the o-rings, accumulator and flush the system. I don't think I let it vacuum down long enough the first time, and it may be overcharged with oil. Best vent temp I can get is 55 deg. on the freeway. Decent, but not great.
Got a couple of questions about the retrofit:
1. What's the proper amount of oil to add to a flushed system? What viscosity?
2. Is it advisable to use the variable orifice tubes (VOV)? Or does the standard tube work just as well? Standard is the red one, right?
Nearest I can find on the oil level is from an old Haynes book, Heating & Air Conditioning Systems Manual. Evap, 3oz......Condenser, 1oz.....Accum, 1oz....Compressor, 6oz (it says if new, compressor will ship with 10oz, and to pour 4oz out) So, 11oz total oil charge, sound right?
As for the VOV, this article says the orifice size is "Significantly larger than 0.057 at full open and significantly smaller at idle." Red is .062, I think.
http://www.imcool.com/articles/aircondition/VOV1.htm
