Biggest Lift
V8RaNGeR
Whats the biggest lift they make for a 99 ranger 4wd?
4" superlift plus a 3" performance accessories body lift.
if you can still find a RCD lift, they are 5.5" lift with coilover conversion.
Dixon bros has a nice lift too, i'm not sure how big though. 4 inch suspension I think?
thats because the dixon bros kit isnt meant to be a lift kit. its a long travel kit. you can adjust ur highth depending on your spring rate.
hands down, the best kit you can get out of the box. if i where to spend any money on a kit, this is the one. i know that as soon as i wasted the money on a Superlift kit, id want to upgrade to a better kit.
The RCD started advertising with 5.5"...they've since downed it to 5". You can get 5" out of a Superlift. Superlift is the only one of the two that are still made.
There's a member over at R-F who went from RCD to DBR and reports he lost MAYBE an inch of height up front. That kit is about 3 times as much as the superlift...and thats JUST the front of the DBR kit... I'm waiting to see when and if someone would bolt a superlift to the truck, add DBR arms and longer coil-overs... That would be right about 8" suspension lift AND long travel. On paper, it should work.
