Bigger fuel tank
SniperJJ10
Maine
I have the 20 gallon fuel tank, 4.0 V6 5 speed. Theres a place in New Jersey that sells a 35 gallon tank, but they say it's 'diesel only.' If the tank is new, chemically it won't matter, but that doesnt mean it'll hook to my fuel neck. Does anyone have any ideas?
Years back, there was an optional secondary tank. If you check your bed, you should even be able to see the bump where the second filler neck was suppose to route. The tank replaced the spare tire, displacing it to the bed.
There isn't a ton of extra space under the stock bed for a larger fuel tank although if you can, go with a larger tank as installing a secondary evap and fuel pump can be frustrating.
I would rekon filler necks at most, would require an adapter of the proper size and material. The evap connections may be different between the two though
If you need to carry extra gas, carry a good gas can. I toyed with the idea of an extra tank that will sit where the spare is, and hook to the main tank to "fill" that one. It is a lot of work.
I found a different website that sells the same tank as I mentioned earlier. Will the neck work to hook up to mine? It says it's for '07 to '11. Mine is an '07, my only concern is they specify diesel only.
Thats for the T6(international) Ranger, same size as the 2019/20 US Rangers, not the 1983-2011 US Rangers
Just get under your Ranger and see if the fuel tank can be expanded forward or backwards or to the center
It can't, well not by much so not worthwhile
Some have added a Bronco II tank in place of the spare tire but it sits low, you can raise up the bed a bit but then it doesn't line up with cab, so you are looking at a body lift
There is no off-the-shelf tank for our smaller US Rangers larger than 20gallon
Tank in the bed is best option if you need the extra fuel storage and you can just siphon it into the lower tank so no "plumbing" is needed
You can get/make a filler hose that would fit just about any gas tank you can fit, so thats not a big concern
Hooking back up the EVAP system and sourcing a fuel pump assembly with pressure regulator would be what would be harder, but can be done
Hooking back up the EVAP system and sourcing a fuel pump assembly would be what would be harder
Why would their rangers be bigger than ours? Here's the actual site.
The “World Ranger” or T6 is pretty much the new body 2019-2020 North America Ranger. If you’ve seen a new one next to your ‘07, you’d see the size difference.
Have you noticed the companies you’ve linked aren’t in the US? That’s because those trucks aren’t in the US.
That's weird. Any idea why they got a bigger truck than we did?
Regardless, I looked under my rig. No room for that tank, not without some massive mods. Thank you, good sir!
Fuel range is a much bigger issue in other places in the world than in the US.
Because people wanted bigger and Ford decided not to bring the new truck everybody else got like in 2010-11 to the US until 2019.
Mazda and Ford started making the BT-50 and T6 Rangers in Asia and South Africa, these were never sold in the US/Canada, they couldn't pass safety or emissions tests so couldn't be imported either
Why were they bigger?
I don't know, you would need to ask Mazda or Ford, it was only slightly smaller than the F-150, which was why Ford was not in a hurry to sell that size here in the US, while it is a smaller truck its not a small truck like our older Rangers
It probably has to do with other car makers going to the larger "small truck" in international markets
In 2019 Ford used the T6 platform for the new Rangers here, it has the required safety and emissions for US/Canada market and is built in the US
I knew something was wrong with this picture... nobody sells a 30 gallon tank for an 07 NA ranger lol. If they did I'd have one...
Bronco II tank in place of the spare tire is about the only option other than putting it in the bed. Some early Rangers did get factory dual tanks but it’s pretty rare. B2 tank holds 23 gallons. Could probably source some parts from a dual tank F-150. I’ve toyed with the idea a few times over the years but never really gave it a go. Been thinking about doing some kind of dual fuel in my Ranger (pump gas and a secondary with race gas), but I’m in no hurry, just kicking around ideas.
I've considered the spare fuel tank mod but it would be a major endeavor and I would need to probably pay someone or get help. While I'm quite capable, this one is beyond, or at least portions of it it, my equipment and skill set.
You can pull the bed off and have a look, there is room if spare tire is not there, but then no spare tire, maybe on a tailgate mount
There are loads of smaller tanks, 12-16gal that would fit without being too low or too wide
Filler can be a bit of a puzzle, on where to put the nozzle port, to make it look clean
If you have to pass emission test in your location then you have to have the EVAP system on both tanks, unless 2nd tank is well hidden, lol
If you paid someone to do it they would need to install EVAP system regardless because I think its like Cat Converters, a Federal beef, to not have it
