big susp. lift
JerseyBoy
south jersey
hey i have a 1997 ranger that has a 6 inc suspenchin and a 3 inc body but i want to go taller. i want to put a 12 inc suspenchin lift in the truck but the bigist one i can find is a 8 inc set up. dose any one make one as big as 12 inc or do i need to bild it my self. also i dont want to use blocks on the leaf springs i just want all leaf in the back and springs in the front can any one help me?? or tell me if theres any threads started about this that i can lern from?? thanks
Solid axle anyone?
Biggest kits i've seen for the 97 and older TTB style suspension is a 6". Add a bodylift to it, and you're at 9". Your next option is putting a solid axle under the front. What size tires are you looking at running?
anything over 6" and you wont be able to correct your steeting or anything. solid axle swap is about your only option for something that big
i would love to do an SAS on my truck and i do plane on it and i want to run 38's under her but i dont realy know where to start the transfermashin:icon_welder:
hope you run 38s on your ttb35
go into the tec library, there is some info there. ur from jersey? where at?
I doubt it. Although, it is April and he does sound like a fool. :dunno:
:shok:
come to jersey ill tech ya what a fool is.:thefinger: and to the other guys the truck has a 3 inc boddy life, a 6 inc suspenchen lift.. and i want to throw away the 6 inc lift for a 12 inc one( if you can do math that would put my truck at 15 inc of lift) but the problom is the bigist one i can find is an 8 inc lift. if you cant under stand that then some one must have shown you how we say hello in SOUTH JERSEY but if they didnt come on down to AC NJ and ill show ya:black_eye:
15in lift and 38s u biulding just for off road toy i hope where u at in jersey
There are very good reasons why no manufacturer will touch a lift bigger than 8 inches. Most won't go above 6, and even that is at the outside end of what is safe without major steering work.
