Big Orange Bug
lil'_big_truck
Detroit
Hey all, here is my 1976 Baja Bug with a 68 motor. I'm restoring it mechanically. I picked it up for only $1200! :yahoo: Its frame and body are solid with only minor rust on the floor and body (considering its age and the fact that its been in Michigan and Ohio its whole life). I need to clean up and fix up the motor, fix the brakes, the interior, speedo, and that's about all that's left. I need to patch the floors a bit, and depending on funding, bodywork and paint. I might also build a speaker box behind the back seat considering it has no speakers.
-replaced generator
-replaced starter
-replaced shocks
-cleaned carburetor
-removed ghetto-rigged stereo
-new 1915cc engine
-new wiring harness
-new brake system
-new floors
-new heater channels
-new paint
-tires
- new interior
- custom gauge cluster
- high performance sway bar
- breather box
- external oil cooler
- new steering column and tire rods
- windshield wipers!
- radio
- temporary seat fix
Next on the list:
- new seat upholstery
Big Orange Bug
Big Orange Bug
Big Orange Bug
Big Orange Bug
Big Orange Bug
replacing shocks
Big Orange Bug
Big Orange Bug
the rears had pneumatic adjustable shocks that looked stock, I don't think I'll replace them as long as they're still working.
Big Orange Bug
Replacing the generator:
Big Orange Bug
You can't see it but, the belt was the original 68 motor's belt. It had huge cracks and it even said "Made in W. Germany". kinda cool / scary
generator
Big Orange Bug
this was a pain to get back in. If you don't do it right, the fan rubs on the metal shroud.
interior:
Big Orange Bug
Next I'll be fixing the brakes and parking brake.
I officially Hate You:D:thefinger::thefinger:
you would not believe how bad I have always wanted a Baja Bug......
l8r, John
haha. you just have to keep your eyes out for them.
so today I replaced the rear shocks, painted the rails, and started work on the front brakes. One caliper was locked shut and the other was on its way out. Now I'm just waiting on new calipers to come in (the closest we in St.Louis Missouri! :bawling:) After that, I should be able to drive around.
When I was working on the rear I noticed something odd. I knew that the parking brake but I didn't know why yet. Apparently someone deliberately cut the lines! who does that? I just can't wrap my head around it.:icon_confused: well that's all for today.
A better pic of the adjustable rear shocks from 76. too bad they don't still work (can't hold any air pressure)haha. not like i really expected them to anyway
Big Orange Bug
Looks good. I picked up a 71 Super a little bit back from a friend. Him and his buddy who owned it, were going to fix it up for a fun car, but his friend passed from cancer. It is sitting right now, just due to house projects.
cool. I'm sorry about his friend. maybe you guys can pick the project back up soon.
today, all I could do was clean the engine a bit so, here it is:
BEFORE
Big Orange Bug
AFTER
Big Orange Bug
Big Orange Bug
also, here are the pesky calipers that I'm waiting on:
Big Orange Bug
That's gonna be all for a bit. Still waiting on parts.
Hey all, So its a pain in the butt to find pads for this thing. I first had to figure out what calipers those were. turns out, they were off a 77 beetle. So I went looking for those, wound up with some off a rabbit that fit right, now I can't find pads :annoyed:. I've got some guys at KOI looking for me and hopefully I'll have some pads tomorrow. In the downtime, I went ahead and wired a voltage gauge so I'd know the battery strength.
Big Orange Bug
It tortures me to have it like this. I want to drive it so bad. haha
Big Orange Bug
Hey all, I'm just posting to let you all know that I got the bug running. Its was a wiring problem that led to me screwing up the timing. So there was no power going to the coil until I bypassed the harness, and then, when I replaced the distributor, I caused the timing to be way out of wack. Now I have a very confusing electrical gremlin. I can't get my blinkers or brake lights to work. They'll come on when I use the hazard flashers or running lights but not when I use the lever or the brake pedal. This might take a while to trouble shoot. I also finally found new calipers and pads that worked. It turns out that the calipers were off of a 72 Karman Ghia. anyway, here are some other updates:
all cleaned up and detailed:
Big Orange Bug
Big Orange Bug
Big Orange Bug
Big Orange Bug
Big Orange Bug
New rubber, the old tires had some serious dry rot:
Big Orange Bug
Big Orange Bug
a local cruise in:
Big Orange Bug
an epic '84 ranger at the cruise in:
Big Orange Bug
hey all, not much has happened but i did get some decals in:
Big Orange Bug
Big Orange Bug
Not sure when I'm gonna get its wiring figured out
hey all, So I have yet to solve my brake lights and signal lights problem. I'm seriously debating just getting a new harness now. On another note, I had to replace my generator's pulley because it broke its teeth and was starting to damage everything else. So I've put on the new pulley and painted my distributor cap for the heck of it.
Big Orange Bug
hey all,
Just a quick update. My dad has convinced me to do a frame off restoration. So I will be starting the process at the end of August. I'm gonna miss driving it for a while, but it will be worth it. The build will have plenty of pics.
Just an update, Got the bug moved to my house and its ready to be torn down.
Big Orange Bug
Big Orange Bug
who says rangers can't do work? haha
Big Orange Bug
my roommate is excited for the build. There will be many pics to come of the teardown
so after day 1, I have most of the fiberglass panels off and started on the windshield. Unfortunately the windshield started to crack even more as i tried to pry it out. Also, some of the bolts holding on the fenders are just spinning in the rust so I may have to grind them off. anyway, pics:
Big Orange Bug
Big Orange Bug
Cool car. Looking forward to your build pics.
Richard
hey all, midway into day 2 and I've got the interior coming apart and the windows.
Big Orange Bug
Big Orange Bug
Big Orange Bug
ok so here are the pics of the beetle mostly torn down. There's a good bit of rust but its not terrible for having been in Ohio and Michigan its whole life.
Big Orange Bug
Big Orange Bug
Big Orange Bug
Big Orange Bug
Big Orange Bug
It looks like I'll be able to send it to a vintage beetle body shop to start getting repaired and repainted in a week or so. I should be pulling the motor tonight to rebuild it. :icon_welder:
