Big brakes on a Ranger.
84ttopcoupe
Is there a big brake solution for 2001 Rangers? Baer, Brembo, Cobra brakes? Anything?
Is your truck 2wd or 4wd? Torsion bar suspension or control arms?
The rotor size and hub diameter will vary depending on the configuration of your truck.
To answer your question point blank, nobody makes a "kit" for big brakes on Rangers. Rangers did eventually come with 11.65" brakes in front in certain configurations, but the ease of that conversion (commonly called the Sport Trac swap) depends on your current setup.k You may even have these already.
Anything else you do (like the custom 13" Cobra brake adapters that have been sold) will require some kind of custom work like a custom caliper adapter.
