or, you could switch to a 5 speed manual tranny. too many problems with the A4LD to swap that in. mine with the 5 speed gets 21+mpg cruising on the freeway at around 65mph. just my $.02.
When my '84 BII had that engine and transmission, I could get 23-25mpg by driving it at 55 on the highway (It was built in days of the 55mph speed limit -maybe that had some bearing on the driveline design) faster or slower speeds brought the mileage down to around 16-18.
You can run a leaner jet. Have you ever rebuilt the carb? What mileage are you currently getting? Are you still running the sock EECIV engine control system? If so a Duraspark swap would also help.
For
