One question, did you need to add extra trans fluid after installing the cooler? And if so, how much?Yes it still runs through the radiator and plumbing it into the existing line was not difficult at all. Attaches at the upper line / upper radiator port with barb fitting adapters. All I had to do was slightly push the OEM hard line over a bit to make room for the rubber lines. No cutting required. Plumbing it was the easiest part of the process. I'll take a pic of how the hoses are hooked up when I go outside.
