03 Ranger
What is the best spark plug to use and can it save gas?
I run copper plugs--I don't mind the shorter maintenance interval that comes with them. Copper is actually better than platinum in terms of conductivity, but platinum & iridium wear longer. That's the sole reason why OEM uses double-plats... they can claim a 100K tune-up interval and that looks better for marketing, and saves them LOTS of money in terms of services done under warranty. But if you don't mind doing a plug change every 30K or so, there's nothing wrong with using copper plugs.
Agreed--particularly if you go by the "correct" service procedure. Coil-on-plug designs, intake configurations, and general cramped quarters in the engine bay can turn something like a plug change into an all day project on some newer cars. My V8 SHO was a classic example--the book time was like 5 hours or something for the plug change. Of course once you figured out the shortcuts you can take w/ the intake removal/disassembly it wasn't so bad, but still, if I took it to a repair facility they'd probably want like $200+ just for the labor.On most newer vehicles it is a severe pain in the pin feathers to change the plugs, which is why the platnums are so common now. It saves them a lot of money during warrentee and the consumer a lot of time/money out of warrentee... trust me it is no fun to stand on your head all day to change out a set of plugs...![]()
I usually recommend sticking with Motorcraft or Autolite, though. Autolite plugs are technically aftermarket but they are made to the OE design specs so they are essentially equal. Anything else that sounds like it might be a gimmick (SplitFire or ANYTHING by Bosch, for example) is inevitably just that--a gimmick. The only exception would be the "fine wire" iridium plugs like Autolite XP "extreme" which actually work quite well. I'm not sure about the Vulcan, but for most applications Ford has superceded the original plug specs with fine-wire double platinum designs, so that's probably what you'll get if you buy Motorcraft plugs today.
I'm not failing to realize any of that information. Just because I didn't mention it doesn't mean I'm not cognizant of it. I was just pointing out that platinum isn't better from an electrical standpoint until tens of thousands of miles go by and its better durability starts to pay off.There are some people that feel that a platinum plug gives a better spark. That's only true when you compare it to a copper plug at 40K miles or so when the copper has been eroded significantly. As for the fine-wire designs from what I have seen they are great, so that is another point in favor of platinum... copper would never hold up at all in that sort design. By the time you are due for an oil change your plugs would be out at .080"
I went through the whole tune up procedure a little while ago. Plenty of busted knuckles on the plugs. I went with Iridium plugs, E3s I think. The ones with the four point spark instead of one. Didn't notice much of a power increase but gas mileage went up 1 or 2 mpg and it idles a whole lot smoother than before. Plugs weren't really fouled or anything but I didn't know the last time they had been changed so I went with high quality the first time around and so far they work great.
