best shackle hanger combo to run with g50s?
94ranger#22
Havasu
I got my Deaver G50 packs on, they ride amazing. But my stock shackles are shot. So I was wondering what combo would work best, not looking to spend over about 150 either. I found these drop hangers and then maybe a bell tech shackle.. Any opinions?
http://www.kartek.com/Product/Suspension/Shackles.html
i've seen alot of people run the stock shackle mount flipped with a bell tech shackle. i just extended the stock flipped shackle.
im running similar hangers to the kartek ones, except my friend made them on solidworks and are all tongue and groove. i've heard of the kartek hangers bending, but if you add some gussets and some plating they should be fine. as for shackles, mine are the same as h&m shackles, i believe theyre 6" long. if i remember right, the belltech shackles are straight right? i dont know if youll be able to get the full amount of travel out of the springs with those shackles.
Oh ok. I think I might just save up for some camburg or blitzkrieg shackles and use the kartek hangers.. Should i drill the stock hanger mounting holes out so I can use a 1/2 bolt instead of the stock 3/8?
