Ok, I have a 95 4-cly 5-speed 2wd with 180K on it. I bought it used from the original owner. They think the clutch was done once and I bought it assuming it needed a new clutch. When I got it home, the clutch res. was empty so I filled it. The clutch then seemed to be working but that only lasted a few weeks.
I think I need to have the clutch replaced. Where can I get the best pricing and who makes a good clutch. There are many different brands out there but this is my work truck that will stay mostly stock. I have installed 29x10.5 tires on it and will be installing a 1-2" lift. I may re-gear later if I decide it is too much of a dog. I know I need a slave cyl., clutch disk, pressure plate, throw out bearing. What about a pilot bushing? Should that be replaced as well? Am I better off pulling the trans and seeing what the flywheel looks like or should I just order a new one? I want to buy everything at once so that when the job starts, I can finish it.
Thanks,
James
Thanks,
James
