97ranger22bronco
- Apr 7, 2024
- Dallas, TX
- 2.3 (4 Cylinder)
- Manual
So I was finishing up work on the rear brakes on my '97 and the passenger drum just would not fit right. I got a second opinion from someone and he said that the axle is bent? He took a look at my driver's side and noted the same thing, as you turn the drum it gets tight and loose periodically. On the passenger side, it doesn't turn very well at all.
So, at this point, is his assumption correct that the axles are bent? And if so, how can I fix it? They're 10 inch brakes and it's a RWD '97 XLT with a 2.3
