grlnbear04
- Dec 12, 2010
- Automatic
Could someone tell me the best way to shim the tensioner. I can see that the tensioner is out of line and I wanted to try and shim it to straighten it out.
Like I said, 3.0 tensioners are poorly designed, and buying a new one does not guaranty that it will be straight once installed. I shimmed my OEM tensioner 7 or 8 years ago, and it's still straight with no sign of belt squeal.
Glad to help out. Out of alignment tensioners are common to the 3.0 engine, and I'll bet if you were to put a straight edge on your tensioner pulley and reference it to your crank pulley you would find that your tensioner is indeed out of alignment.Thanks McCormack.
I think I'm going to give the shim's a try. I've tried a lot of different things to get rid of the squealing with no success.
I went and shimmed the tentioner and put a new belt on and no more squeal. Thanks for the advice McCormack.
