Pekerz
Hello everyone, I have a 1993 Ford Ranger 3.0 and my belt is really loose. Can I adjust the tension or will I have to replace my tensioner and its pulley?
Thank you for the replyIf you have a tensioner that uses spring pressure to keep the belt tight, you'll need a new tesioner. The pulley usually comes with it.
If your tensioner is the old style that uses a bolt to increase the pressure or a pinch bolt and a slide arm, you'll need the diagram with the proper a.ount of belt play and where to measure it from. Measurement location makes a difference.
Thank you for the reply. I there a way for me to be certain if it is spring pressurized or if I can adjust it manually? I have looked all over google and I can’t seem to figure it out. Thanks again
