Camo Ranger
Hey this is my first post on TRS but I've been a fan for a while now and I've read through a ton of forums on here for advice. I was hoping someone could give me some advice with an certain annoying issue I have...
I bought my truck a year ago this past september. Once the weather started getting cold the serpentine belt started squealing. At first it only squealed when the truck was cold and then it went away once everthying warmed up. Then, as winter progressed, it started not going away and getting louder and louder. Once spring came around I replaced the idler pulley (had about a quarter inch of play in it) and then later the serpentine belt itself. Both times the belt squeal went away for a few months. However, now the squeals back and once again it seems to be getting worse and worse as time progresses. I'm thinking its probably the auto tensioner, but I don't wanna go spending $60 on something that doesn't need replacing (poor college student funds). Any advice? Also, if I do replace the auto tensioner, should I replace the belt too (thinking gatorback)? Thanks in advance.
