Here's what I started with:
I am using the FEAD off of a '90 Lincoln MK VII. I didn't need/want the A/C or the Thermactor (Air or Smog) Pump (what ever you want to call it!). So here's what I did.
Proform makes an "Air Pump Idler Bracket", and it comes with a 4-1/4" idler pulley.
Minor problem - Major expense!
I needed the 5" idler. Sooo... ...off to NAPA...
Now, this works fine, but it
was an expensive proposition
+$91.34 for the Proform Idler Bracket (at Auto Zone), and
+$30.44 for the 5" Idler Pulley (at NAPA)
$121.78 just to get the Air Pump Idler right. AND STILL USE THE "STOCK BELT SIZE".
Note: If anyone out there knows of a less expensive way to do this
properly - I repeat "do this
properly", please post it.
_____________________________________
The A/C Compressor Bypass Pulley, on the other hand, was a perfect match and fit for my application. It is made by Motormite and I paid $36.74 for it at Auto Zone.
This FEAD setup operates very quietly. I'm satisfied with it overall - once I got over the cost of the Air Pump Idler Bracket.
I highly recommend keeping the serpentine belt arrangement, but don't know quite what to suggest to you for the Power Steering, except to play with various belt lengths until you get one that fits right. I've played that game, too. It can be frustrating - trips back and forth to the Parts Store until you get it right. Just make sure that your favorite Counterman is aware of what you are doing, so he doesn't get exasperated with you when you walk in for the fourth time to say, "This one doesn't fit -- either!"
If your Marquis FEAD is similar to my Lincoln FEAD, (look back up at my 1st pic) it looks like you'd have plenty of clearance to come straight down to the crank pulley from an "A/C Compressor Bypass Pulley", then play the belt length game. You might even be able to eliminate the Power Steering Pump Bracket. Not that it weighs alot, but it would give you some extra oil filter relocation room for hoses.
Personally, I might be tempted to go to Pick-N-Pull and get a Power Steering Gearbox. Best to ya' !
