Belt chirp/squeal
Detroit
MI - USA
Vehicle
Drive
Howdy all. Got an '05 FX4 automatic with a recurring belt chirp/squeal that is making me park the truck due to noise. Usually silent when cold, then slowly gets worse as things warm up over a drive. I've loaded the parts cannon and everything seems to help for a short while, then it always comes back. Here's what I've done:
  • ~100mi after buying the truck, squeak started, and a new Gates belt worked for 5,000 miles, then it returned
  • Cleaned some pulleys, worked for another ~100mi, then returned
  • Installed a Gates kit with tensioner, belt, and idler pulley. Worked for ~1,000 miles, then returned.
  • Since then, the following "fixes" have worked for a max of a few drives:
    • Cleaned all pulleys with brass brush and solvent
    • New Dorman harmonic balancer
    • New alternator
    • New Motorcraft belt
    • New Dayco idler pulley
    • Reman power steering pump (old shaft seal was leaking, thought it was contaminating the belt)
Took it to a shop, they said it was the fan clutch. I removed the fan assembly and it still squeaked, so $80 diag fee wasted.
Some more details:
  • Spraying water instantly quiets the noise, and holding a wet rag to the smooth side works as well
  • All pulleys look straight with very little wobble if any
  • There is a valve cover leak that I'm going to tackle, but I don't think it reaches the belt
  • Does not noticeably change with A/C on/off, turning the wheel, or loading the electrical
  • Seems worse at idle. Could just be road/engine noise masking it during accel
I'm about to gamble on a new fan clutch, water pump, and pulley just because. With that done, the only thing left is the A/C pulley/clutch, but nothing is making me suspect it other than process of elimination.
At a loss on this one, any ideas?
One of your pulleys might be dragging a bit. You're saying you're going through belts real quick? It might be your tensioner pulley, if it's the back side of the belt getting wet that fixes the issue...
Hmm I wouldn't say I'm "going through belts" since they don't seem to be getting damaged... Tensioner pulley runs on the ribbed side of the belt, and it's new as well. I agree that maybe a pulley is dragging, probably worse when hot? I'm suspecting the water pump and have one in the mail, so I guess we'll see
I’m fighting this same issue. My belt chirps. I’ve replaced the harmonic balancer (it was starting to come apart), the water pump, tensioner, idler pulley and just spent $200 to replace a perfectly good alternator and nothing has worked! Also tried a shorter belt. A little water on the back side of the belt silences it briefly. I’m pulling my hair out! I don’t know what else to do! My mechanic said everything is in line. He said that the alternator was out by 1/8” thus the replacement. So annoying!
Get a mechanic's stethoscope and touch it to the pulley mounts with the engine idling. You may hear where the issue is loudest. Just watch your hands!
Can you check this? The tensioner pulley should be on the back (smooth) side of the serpentine belt, not on the ribbed side. A diagram showing proper routing should be on a label under the hood, on the radiator bulkhead.
01-12 4.0 rangers. I had to look it up also because I don't think I've come across a tensioner on the rubber side before.
  • Belt chirp/squeal
  • Belt chirp/squeal
These two idler pulleys are the only possible places the belt could squeal unless you have a foreign object contacting the belt. Even if the bearings are good, if those pulleys are angled at all (bent bracket, washer missing) it'll do what you're talking about, even if it doesn't have the ability to de-belt the system. Try this: color the pulleys with a large tip permanent marker and look for erasure marks. If you see any kind of crosshatching or bare spots, you have likely found the issue. I would say not to idle more than a few seconds, or you could crank it without starting it.
Sorry all, stopped getting notifications for responses to the thread for some reason.
I replaced the fan clutch since the shop told me it was bad (it did wobble a good amount) even though it still squeaked with the entire fan assembly removed. It was cheap, and I also grabbed a water pump pulley.
New water pump pulley seems to have fixed the issue, at least for the last 800 miles. Has been silent through dry weather, rain storms, puddles, and highway trips. Will report if it comes back.
I have a new very minor issue: the new fan clutch is basically locked for the first ~~1000ft of driving on a cold start and spins the fan very fast/loud until it warms up, then it's fine until the next cold start. Is this normal?
That's what mine does. I guess it's normal. All the cars I've ever owned idled high at first. This is the only one I've owned that has had a belt-driven or crank-driven fan.
