- Nov 13, 2018
- Canaan
- State - Country
- NH - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- Automatic
- Total Drop
- 3"
- Tire Size
- 235/55R16
- My credo
- If you don't have time to do it right will you have time to do it over?
It sounds like you're describing loose front end parts to me. Do they know what to look for on a TIB- radius arm bushings, etc? Any alignment tech should first check the tire pressure, then for loose/worn parts, then the ride height before doing the alignment. My guys always did but we were not flat rate so they didn't have to cut corners to make a living. I would request a printout and that everything be set to the preferred specs- not just "in the green". For example, the toe in could be at max allowable and the camber could be at max positive allowable and both would be "in the green" but the vehicle would chew the outside of the tread right off.
