Bed Slide Solutions by Cargo Ease for 2020 Ford Ranger at CARiD
carid
Supporting Vendor
Cranbury, NJ
No more crawling around in your Ford Ranger's bed or straining yourself trying to grab your cargo. Cargo Ease pullout truck slides put an end to all that, and now they are available for 2020 Ford Ranger!
Cargo Ease makes it easy to load and unload your truck bed. By putting all your stuff right where you need it, these slides prevent injury and provide maximum convenience to your cargo-hauling endeavors. Thanks to the strong steel construction, the slide is sure to withstand long years of everyday use. The deck of the system is built of premium quality plywood and then covered with a high-density polyethylene coating. Simply pull the truck bed slide towards you and grab everything you need. When you're done, simply push the bed slide back, and you are good to go.
Cargo Ease™ | Bed Slides & Truck Accessories — CARiD.com
Make your truck bed work for you with Cargo Ease Bed Slide!​
