Denver95327
- Feb 7, 2013
So I just bought a 93 ford ranger from a buddy of mine due to unfortunate reasons, I knew the engine needed some work due to a knock, well here I am looking for ideas of what the causes may be. It is a 4.0, When you first start truck it knocks for 1-2 seconds until oil builds pressure..then goes away. When engine gets warmed up a bit the knock comes back and doesn't go away. If you're driving along and get on the throttle the knock does go away but comes back when driving normally. I was thinking a rod bearing, but was told to do the trick of pulling each spark plug wire one at a time to see when the knocking goes away, well it never did go away . So maybe the crank bearing? The sound is hard to pin point where it is coming from, top or bottom of engine. Another issue I am having is that oil pressure does drop when engine is hot and at idle. Truck seems to have good power still and runs ok, If anyone has advice on this is would be greatly appreciated. Also, this is just a hunting truck for the woods, not a daily driver so it might not be worth dumping much money into. Thank you for your help.
