Bearing, Hub or something else?
some-bitch.
Some things you just have to smile at. I did not have time to drop the differential last night (replacing all 3 u-joints and the housing seals), so we did it this evening. Get it out, set it on the bench and :shout:
Some idiot broke the bolt that holds the pin, drilled it, and then abandon the cause and bolted the housing back up. To the unknown idiot that did this ----> :thefinger:
LH twist drill bit...
I got it out. Luckily they had put the bolt into the drift pin so I was able to get it out with a punch.
