Mark_88
- Aug 11, 2007
- Age
- 69
- Ontario, Canada
- Automatic
- My credo
- Love Thy Neighbor
I read something on this a while ago but couldn't find it...I received a used battery yesterday and found it to be a top/side post model...I happened to flip the battery on it's side to check something and didn't realize it was one of those 'serviceable' batteries...and some of the water leaked out.
I read that you're supposed to use non-ionized and demineralized water only to top up a battery, but I couldn't find any. So I put in about a cup of reverse osmosis purified water. The only information I could find on this is that using water that is ionized or has minerals can cause the battery to fail prematurely.
Well, I had to jump the battery and let the engine run at a higher idle for about a half hour to try to charge it up, and then shut down the truck to see if there was any more juice. The truck started with the first turn of the key...but I'm going to test it tomorrow morning again...
The battery is rated at 875 amps and 125 min, and the old one was rated at 660 amps and 100 min. It seems to be a much stronger (and is newer) battery than the old one...hopefully it works better...
Sooooo...my question is...anyone have any experience with this?
