I am looking for some general input. This is actually for a 94 Jeep Cherokee
We've had a problem with battery getting discharged over a relatively short period. Typically days.
I was/am pretty sure it isn't the battery itself, but after the battery had been hammered flat a few times and left that way for a couple weeks I didn't trust the battery. It has a new battery, it hasn't been allowed to go completely flat but it has gotten down to where there is not enough energy to crank the engine more than a few seconds.
Sometimes it goes a couple days, sometimes (like last night) it goes from fully charged to not enough to start the engine in about 20 hours.
Disconnecting the ground and looking at the load with everything off I am seeing 0.30 Amp. To me that is a bit high, but is a rate I would expect to cause problems after a week, not overnight.
Still I hunted that down, when I pulled the fuse marked for radio light, dome light, etc the current dropped down to 0.02 Amp. Okay maybe that is it. But I noticed a second fuse labeled for essentially the same thing. So I put the first fuse in and pulled the second. The same 0.02 Amp. I put both fuses back in and expected to see 0.30A, but with both fuses in it still shows 0.02A. Leaves me scratching my head.
Anyway that doesn't seem enough either way to cause the discharge as fast as it has been happening.
I also noted that with the door open there was a 2.5A draw. That seemed to bit high to me. Am I right that seems a bit high? Also despite the other fuses being labeled for the dome light, the dome light functioned in both cases when the fuse was pulled.
Other thing is that this vehicle has an after marked automatic starter and alarm. I suspect that is doing something odd and would like to pull it out as it has been more headaches than it is worth, but have no idea where to start looking. I see a bundle with some sort of unit taped up in the harness under the dash, but not sure if it is it and not sure what the make or model of the starter is.
Any thoughts or suggestions would be appreciated. I do know electrical stuff outside vehicles, but are uncertain of the norms in the vehicle and the odd things that typically go wrong.
