I don't think it is on the 2000's. My 98 wouldn't unless you pushed the clock button and then it would light up for a few seconds. I had a battery drain also that i tracked down to it being my factory radio. With the key off every so often you could hear the speakers crackle like power was applied to them. I replaced my factory radio and problem solved it was some intermittant short in the factory radio. hope this helps.
I just noticed that not only does the clock stay on all the time but the "theft" light flashes constantly with the key off. Is this normal? Is there a way to disable the theft alarm?
I pulled the fuse from the radio but the battery still drains, though maybe a bit slower.
For
