Battery dies after 24 hours parked
p38fln
Superior, WI
This one has everyone I ask stumped - if I leave the truck sitting for more than 24 hours, it is dead. Very dead, as in no dome lights and the presets are all gone from the radio. I already replaced the battery, which did nothing, except possibly make the problem worse.
So I got this 400 AC/DC amp clamp meter from Sears...expensive, but a huge improvement over trying to get an in-line meter into the wiring.
And in the end, I think that all I really managed to do was prove that there was nothing wrong... Any ideas?
Just so my afternoon with the amp-meter isn't totally wasted, I'm posting the readings below. Somehow, the amp meter can tell if the battery is getting discharged and puts a - symbol in front of the reading. It switched to a positive readout once the battery was being charged. Haven't got a clue how it does this, or how it works in the first place since it's reading DC amperage through a clamp.
Engine off, key out (Measured by putting both positive battery cables into the amp meter clamp together)
Nothing on -
-0.27 amps (This is the same reading that an in-line 10 amp amp-meter gave)
XM Radio and power invertor with no load -
-0.78 amps (This is also the same reading that the in-line meter gave)
Parking lights (Switched range from 40 to 400 amps)
-9.8 amps (And, once again, the same - but it blew the fuse in the in-line meter immediately afterwards so I stopped and bought the clamp-on type)
Low beam headlights -
-17.2 amps
High beam headlights -
-18.6 amps
Engine start -
-307 amps, then +35 amps, gradually falling to +5.9 to +5.2 (I turned everything in the truck on then off, and the amp meter stayed in the +5.2 to +5.9 range no matter what I did)
Engine idling - Testing at hot wire of alternator, can't remember if the - symbol lit up or not.
Nothing on, just engine idling -
19 amps
Every possible electronic gadget turned on (Radio, Max AC, high beam headlights)
48 amps
And, with the engine off, the hot wire of the alternator reads 0.00 amps.
You need to do a parasitic draw test.
Does that meter go down as far a milliamps? Really any cheap digital DVOM would have been just fine. Simply disconnect the positive terminal at the batter, attach one lead to the battery post and the other to the positive cable. Keys out, truck off, doors closed, hood light out, all aftermarket accessories off. You will then see if you have a draw in the truck that is killing the battery. Anything under 0.05 of an amp is acceptable. Anything over that and you start looking for the problem. Start pulling fuses one at a time, checking if you draw goes away when you pull that fuse. If it does, your problem lies in whatever circuit you just pulled the fuse for.
I was wondering if the 0.27 was high. It measures down to 1/100th of an amp :) Nice little device, I love not having to pull the wires loose to check things.
Yes it is, start pulling fuses till you find the circuit causing the problem.
